Changed O2 sensor jeep wont start!
Discussion in 'Wrangler JK (2007-2017)' started by Bigfoot Tracker, Oct 6, 2019.
  1. Oct 6, 2019 at 10:25 AM
    Bigfoot Tracker
    Bigfoot Tracker [OP] New Member
    John
    So i changed the O2 sensor on bank 1 sensor 2 because of a misfire and a P0137 code.
    After putting in the new sensor, I went to start my jeep and it wont start.
    All the lights come on and when I turn the key, it cranks but no start. :( sounds like it isnt getting fuel or spark now.
    It's my only vehicle and I need this fixed asap. Its stuck at my job right now and I have to rely on rides to get to and from work. I have no idea what to do.
    [Jeep info] 2008 wrangler x 2 door manual
  2. Oct 6, 2019 at 12:25 PM
    Welcome @Bigfoot Tracker ...changed several O2 sensors in the past and never had a no start. Got any engine codes? Used a quality brand O2 sensor? Any outstanding codes?
  3. Oct 6, 2019 at 1:14 PM
    lets try unplugging the o2 sensor - see if it starts. ADVISE
    Do you have a scanner able to see live data??
    FYI: the code P0137-O2 SENSOR 1/2 CIRCUIT LOW,
    We need ALL the codes posted.
    Quick question with key on is the odometer displaying mileage?
    Passenger side is bank 1, SENSOR 2 is post cat or rear most sensor.
  4. Oct 12, 2019 at 7:02 PM
    Bigfoot Tracker
    John
    Thank you for your replies. I totally appreciate it. I ended up tapping on the crank sensor with a ratchet extension and it fired up. I must have bumped it the wrong way when I was changing the o2 sensor.
    BigAL07, boondoc89 and aggrex like this.
