Changed struts and now it bangs over every bump
Discussion in 'Suspension' started by Ezmac43, Oct 14, 2021.
  1. Oct 14, 2021 at 11:08 AM
    Ezmac43
    Ezmac43 [OP] New Member
    2014 Grand Cherokee
    Hey gentlemen….hope someone can help with my 2014 grand Cherokee….changed the struts at Mavis and it came back banging every time I go over a bump, like it’s hitting the road….
  2. Oct 14, 2021 at 4:52 PM
    Tough to help without any pics of the suspension/installation or brand/model# of the replacement struts. Going back to Mavis and having a conversation is probably the best thing to do.
    Groundfault and LYFZGOOD like this.
  3. Oct 15, 2021 at 1:40 AM
    Ezmac43
    2014 Grand Cherokee
    Did that…they claim there was a faulty strut, and they supposed to have fixed it but it’s the same….I’m wondering if there was a 2" lift and they didn’t put it back….
  4. Oct 15, 2021 at 4:05 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    Stock shocks will work with a maximum 2" spacer lift on Cherokee's. Are the tires stock size? Although unlikely, you might want to verify that they put the right shocks on it. Too long or short and the shock might not have the travel during compression or droop.
    If the shock is running out of compression before the bump stops hit, it'll destroy the shocks.
