Check Gauge light flashes
Discussion in 'Wrangler TJ (1996-2006)' started by Raven Gray, May 5, 2021.
  1. May 5, 2021 at 7:34 PM
    Raven Gray
    Raven Gray [OP] Member
    97 TJ 2.5 Lil Dog
    Any advice or ideas on what is causing the "Check Gauges" light to flash? Not the check engine rather the check gauges. All dash gauges seem to be working. The warning is brief. It typically "flashes" when I come to stop and shift into reverse. It last for a second at most. This is on a 97 TJ 2.5lt manual.
    Thanks
