Chrysler after market keep alarm
Discussion in 'Wrangler TJ (1996-2006)' started by Fester7373, Aug 19, 2019.
  1. Aug 19, 2019 at 5:21 PM
    Fester7373
    Fester7373 [OP] New Member
    can anyone tell me how to change the red light valet mode switch on the alarm.
  2. Aug 19, 2019 at 5:24 PM
    Fester7373
    If not how to disable/remove the alarm all together.
  3. Aug 19, 2019 at 6:42 PM
    Seems you have the switch in your hand already. Use some electric tape to cover and tuck under the dash. Without a wiring diagram of the aftermarket unit removal may create another issue.
  4. Aug 20, 2019 at 7:20 AM
    Fester7373
    Do you know of a way to change the switch with one that works.
  5. Aug 20, 2019 at 8:19 AM
    If you're up to it replacing the switch is not too difficult. Remove the protective sheathing, identify where the wires attach, get a comparable switch and replace. Anything more involved be sure to obtain a wiring diagram for the specific alarm system.
