CJ rear bumper bolts
Discussion in 'CJ' started by unclejohnny75, May 4, 2020.
  1. May 4, 2020 at 10:55 AM
    unclejohnny75
    unclejohnny75 [OP] Member
    John
    1981 CJ7
    I bought an aftermarket bumper for my 1981 CJ7. The instructions say to use the two factory bolts that thread into the frame from the bottom. The bolts that mount horizontally were included with the new bumper. My jeep didn't have a bumper when I bought it, so I need to purchase those two bolts. I have had no luck in finding the size of those bolts.
  2. May 4, 2020 at 11:16 AM
    Welcome @unclejohnny75 ...start the search by contacting Quadratec.com for miscellaneous CJ parts. Local hardware store might be able to help
  3. May 4, 2020 at 3:17 PM
    Yeah, I would suggest contacting a bumper manufacturer for that one. The best way to mount a bumper of any kind of a CJ is to transfer the load from the oem CJ bumperette mounts to the frame.
  4. May 4, 2020 at 3:30 PM
    unclejohnny75
    John
    1981 CJ7
    There are 8 bolts that connect the bumper to the jeep horizontally. I'm asking about the two bolts that mount the bumper from the bottom. Per the instructions the stock bumper had ten bolts holding it together also. These two bolts appear to screw directly into threaded portions of the frame.
  5. May 11, 2020 at 9:19 AM
    SrdjanDV
    SrdjanDV Active Member
    Srdjan
    If you are talking about this bolts..
    543576_236_full.jpg those bolts are 7/16 -14 on my 95 YJ
  6. May 11, 2020 at 9:29 AM
    unclejohnny75
    John
    1981 CJ7
    Those are the bolts in question, but funny story...I went to my local fastener place, and we realized the threads are stripped out on one side, so a drillbit and a tap are going to be in my future. Thanks for the info.
  7. May 12, 2020 at 6:39 AM
    Check with Napa you can purchase what’s called a Heli coil set you can buy them in various different sizes and drill out the old threads and put in new ones they come with a drill bit a tap and a tool to install the new threads. Good luck
  8. May 12, 2020 at 4:00 PM
    Yeah, those are 7/16-14 bolts going into the rear shackle hangars. A heli-coil should work just fine.
    Edit: Try and get some stainless ones.
