CJ5 won't crank after new control module installed
Discussion in 'CJ' started by 75cj5, Aug 31, 2017.
  1. Aug 31, 2017 at 11:10 AM
    75cj5
    75cj5 [OP] Member
    Yellow 1975 cj5
    My ignition control module is getting so hot that it's melting. The jeep still cranks and runs, but I ordered a new module anyways. When I installed the new part I could not get the jeep to crank. Could this just be a grounding problem or what? Oh I have a 1975 cj5.
  2. Aug 31, 2017 at 7:22 PM
    Best thing I ever did was junk the Ford ICM, coil, and distributor that AMC used in the cj, and replaced it with a HEI distributor. This is what I suggest you do, but if you want to keep your set up we need more information. What to you mean by won't crank? Will it turn over, but not start, Or when you turn the key nothing happens?
  3. Aug 31, 2017 at 7:36 PM
    I'm subbed. I have no idea what your issue might be.
    But I constantly learn from OFFGRID. Another learning thread for sure. :)
  4. Sep 5, 2017 at 9:33 AM
    75cj5
    75cj5 [OP] Member
    Yellow 1975 cj5
    I will check into that setup but money and time wise I'll have to stick with this for right now but yes it will turn over just not start.
  5. Sep 13, 2017 at 6:27 PM
    Turning over and not starting is spark, or fuel. Probably not the CM, but a coil or the electronics of the distributor if it is a spark issue. If not it is likely the fuel pump.
  6. Sep 14, 2017 at 3:43 PM
    75cj5
    75cj5 [OP] Member
    Yellow 1975 cj5
    That's what I was thinking but it cranks with the old cm just not the new one is what has me confused
  7. Sep 14, 2017 at 4:10 PM
    Have you put the old one back in to see if it will start. Where is it melting? The under side? Mine did the same thing. They all get hot. That gel just gets old and sort of comes apart. I think I paid less than $100 for my HEI on eBay. Fixed all my ignition problems.
  8. Sep 14, 2017 at 4:13 PM
    75cj5
    75cj5 [OP] Member
    Yellow 1975 cj5
    Yeah it's the underside the black gel that's melting and I put the old one back in and it started right up
  9. Sep 14, 2017 at 5:28 PM
    Sounds like The new one is a faulty CM.
  10. Sep 15, 2017 at 11:51 AM
    75cj5
    75cj5 [OP] Member
    Yellow 1975 cj5
    Alright thanks and ill check on the HEI
