Clunk sound
Discussion in 'Wrangler TJ (1996-2006)' started by jeep3237, Sep 17, 2017.
  1. Sep 17, 2017 at 4:38 PM
    jeep3237
    jeep3237 [OP] Member
    George
    2006 Jeep Wrangler Sport
    I hear a clunking sound coming from the rear of my TJ when I go over bumps or turn. When I push sideways on the back tires I can hear it but I cannot find where it is coming from. Anyone have any ideas???
  2. Sep 17, 2017 at 5:22 PM
    Might be best to have a friend lay under it, while you shake it. See if you can isolate the sound that way.
  3. Sep 17, 2017 at 5:28 PM
    Simple clunk sounds while parked could be loose or worn shock or sway bar mounts/bushings. Clunk sounds while in motion could be more serious/involved like u-joints, bearings, gears. Others may chime in with TJ-specific experience.
