Clutch problem on a CJ7
Discussion in 'CJ' started by OFFGRID, Oct 7, 2016.
  1. Oct 7, 2016 at 9:02 PM
    OFFGRID [OP] Well-Known Member
    So I spent the evening helping a friend get his 84/85 CJ7 started and running after he had the 258 rebuilt. I got it started. While he had the motor out he installed a new LUK clutch kit. He and another friend stabbed in the motor last weekend. Now the problem. The clutch feels like it is continually engaged. The VIN says it is an 84, the title says it is an 85, therefore it should have a hydraulic clutch, but it is a manual clutch like the pre80 CJs. It looks just like my 79 clutch linkage. Upon initial test drive, everything was in neutral including tcase and tranny. Holding clutch pressed to the floor and I put the tcase in gear first I cannot get the trany in gear, and if I put the tranny in gear first the tcase grinds trying to go into gear while pressing clutch to the floor, and if I force it the jeep wants to take off. I've adjusted the linkage to have 1in of peddle play, and still the clutch feels like it is engaged even with it pressed to the floor. I took all of the slack out of the peddle and then some and still get the same symptoms. His clutch linkage looks pretty warn. I would like ya'lls thoughts before I pull the tranny and tcase in order to start from scratch. Not always easy going behind someone elses work. I think I'll adjust the linkage tighter and tighter untill it comes off the threads to see if I can get the pressure plate to disengage before I do the big work. Your thoughts please.
  2. Oct 8, 2016 at 6:17 AM
    C2T
    C2T Well-Known Member
    Richard
    Helena, Montana
    Jeep
    Ok...standard questions....any chance the disc is installed backwards? Any chance the pilot bearing got damaged? Did the bell housing fit properly or did you pull it together with the bolts?
    Probably not a help but it's the best I have to offer at the moment.
  3. Oct 8, 2016 at 6:29 AM
    Yeah, I asked him all thos same questions. He could not give me all,of the answers. Sos I'm afraid I will have to pull it all apart. Although the friend who helped him install the motor
    is well respected as a jeep builder. Mistakes do get made.
  4. Oct 8, 2016 at 6:33 AM
    C2T
    Richard
    Helena, Montana
    Jeep
    Yup, mistakes can happen. Personally, I have not attained perfection yet. lol
    Regardless of what it is, I can think of nothing that can be done without taking it back apart.
    Good luck with it.
  5. Oct 8, 2016 at 6:57 AM
    Thanks. I will let you know what I find out.
  6. Oct 8, 2016 at 7:07 AM
    C2T
    Richard
    Helena, Montana
    Jeep
    Good luck...and welcome to the forum.
  7. Oct 8, 2016 at 6:38 PM
    Found the problem. When they installed the new throw-out bearing, the single ball bearing behind the clutch fork fell out.
  8. Oct 8, 2016 at 7:02 PM
    C2T
    Richard
    Helena, Montana
    Jeep
    Glad you found it and it was simple (as much as disassembling all that again can be anyway).
