Coil over conversion
Discussion in 'CJ' started by Rorky77s, Jan 31, 2018.
  1. Jan 31, 2018 at 7:20 AM
    Rorky77s
    Rorky77s [OP] Member
    Roark
    ‘73 CJ5
    Hey guys this is my first jeep. Got a 73 cj5 but I’m having trouble finding an coilover spring conversion kit that’ll fit my model. Want to eliminate the leaf springs. Any ideas?
  2. Jan 31, 2018 at 8:04 AM
    Welcome to the site!
  3. Jan 31, 2018 at 8:20 AM
    Rorky77s
    Roark
    ‘73 CJ5
    Thank you sir!
  4. Jan 31, 2018 at 8:27 AM
    I have never seen a coil over spring kit for a CJ. Only YJs. The only way I know would be to find a TJ axles with all the linkages and order TJ Buckets as well as any other mounting hardware like track bar and shock mounts from a company like Rough Stuff, and weld it in yourself.
  5. Jan 31, 2018 at 11:44 AM
  6. Jan 31, 2018 at 2:39 PM
    Rorky77s
    Roark
    ‘73 CJ5
    Awesome thanks. I’ll have to look into that
  7. Jan 31, 2018 at 3:16 PM
    I am not sure where you are located, but Ironman4x4fab in Hayesville North Carolina might be able to help you out. They say they do YJ products and the CJ isn't too much different. They also make customer control arms. Might not hurt to give them a call. https://www.ironman4x4fab.com/contact-us
    Also I found that GenRight offers a TJ/YJ/CJ front and rear link kits. They only do 3 link fronts from what I could tell, I would personally rather have a 4 link.
    https://genright.com/products/suspension/3-link-4-link-kits/?sort=featured&page=1
    You might look at linking the front and going with different leaf springs in the back.
    Deaver springs are thicker packs but made up of thinner leaves: https://www.deaverspring.com/
    Or Alcan who springs are made to order: http://www.alcanspring.com/index.htm
  8. Jan 31, 2018 at 5:05 PM
    Offroad798
    Offroad798 Well-Known Member
    Florida
    2015 Rubicon
    Welcome to the site.
  9. Jan 31, 2018 at 5:05 PM
    Rorky77s
    Roark
    ‘73 CJ5
    If I have too! I may end up fabbing my own brackets and making something work. I’ve heard a lot about Ironman in other posts tho. I’ll check that out, thanks
  10. Jan 31, 2018 at 5:07 PM
    Rorky77s
    Roark
    ‘73 CJ5
    Thank you Offroad! I plan on sharing my build with you guys and seeing if this CJ comes out like I picture it
  11. Jan 31, 2018 at 5:09 PM
    Rorky77s
    Roark
    ‘73 CJ5
    This is the only pic so far. This is how I got her.
  12. Jan 31, 2018 at 5:11 PM
    Ah yes.....The Domesticated Caged Jeep. I yearn for the day all Jeep are Free range! :)
    I'll see my way out......:anonymous:
    OFFGRID, JKBob 25 and aggrex like this.
  13. Jan 31, 2018 at 6:15 PM
    Welcome Rorky77s! That's some fine caged heat I mean Jeep. The CJ5 looks great from the pic.
  14. Jan 31, 2018 at 6:39 PM
    Welcome to the forum. @Rorky77s. Wow....for a 73. Looks really clean.
    Imsee you met a few of our more knowledgeable members. @OFFGRID is probably our best CJ guy here. @Prerunner1982, very knowledgeable also when it comes to jeeps and over mechanics.
    Umm this member @chris4x4. Yeah sorry. We apologize for him. Every family has one. You know, the one family member that well.....I'll leave it at that. But he's ok. Just don't pet:boink: or provoke him. Loll.
    When you let your CJ out of her cage. We love to see more pics and progress with her. Best of luck. And welcome again.
  15. Feb 1, 2018 at 9:36 AM
    JKBob 25, Bob and chris4x4 like this.
  16. Feb 1, 2018 at 1:51 PM
    Well I'd like to see some of that caged heat. Them claws be big ones.
    chris4x4, JKBob 25 and Bob like this.
  17. Feb 1, 2018 at 2:06 PM
    :rofl::rofl:. :spy:
  18. Feb 1, 2018 at 6:15 PM
    Found it. Daves customs unlimited makes a 3 link front 4 link rear kit for all CJs to be used with either coil springs or coil overs. https://davescustomsunlimited.com/
    aggrex, Prerunner1982 and JKBob 25 like this.
  19. Feb 7, 2018 at 10:58 AM
    Southeast Overland
    Seneca, South Carolina
    Only big issue with linking CJ's is that the frame is pretty wide, this means that a coil spring or coilover is pretty hard to fit between the tire and the frame unless you have swapped to a full width axle or some crazy backspace wheels on CJ widetrack axles. What motor does your Jeep have in it? V8 Jeeps are rough to fit upper links and clear motor and frame.
    ~Jeff
  20. Jun 1, 2018 at 3:51 PM
    Jonny-jeep
    Jonny-jeep New Member
    1976 cj5
    Genright coil over kit
    Genright off road, they have a pretty sick roll cage also. ​
