Coolant leak
Discussion in 'Wrangler TJ (1996-2006)' started by gentz65, Mar 3, 2025.
  1. Mar 3, 2025 at 9:46 AM
    gentz65
    gentz65 [OP] New Member
    bryan
    coolant is leaking from a hose near the left front area of the bottom of the motor. What is the part called connected to the motor ?
  2. Mar 3, 2025 at 12:52 PM
    The upper radiator hose usually connects to the thermostat housing while the lower radiator hose may connect to the water pump outlet or coolant passage.
    Bob, JKBob 25 and LYFZGOOD like this.
