Coolant reservoir overflow
Discussion in 'Cherokee' started by Rey88, Aug 22, 2019.
  1. Aug 22, 2019 at 8:17 PM
    Rey88
    Rey88 [OP] Well-Known Member
    Temecula California
    93 XJ 4 door
    pretty hot day today, after driving around town for a little, Jeep was getting hot, after I turned it off, the reservoir was pissing coolant like crazy, first time it’s done that coolant is at proper level
    I have a whole new cooling system and replaced fan clutch and radiator but I am missing the electric fan. my question is why would it come out so heavy from the reservoir? I’m scheduled for a 5 hour trip next week so I need to make sure this doesn’t happen again.
    Thank you!
  2. Aug 22, 2019 at 8:38 PM
    Thermostat replaced? Whats the coolant level of the reservoir when engine is cold? What electric fan is missing? Proper coolant mixture?
  3. Aug 23, 2019 at 10:01 AM
    Rey88
    Temecula California
    93 XJ 4 door
    Yes sir thermostat, level when cold is at proper level just up to the full line. Coolant mixture is good. Minus the rust that was in the system when I bought it but I had it flushed multiple times. And the electric fan I’m talking about is the one on the driver side of the radiator, right now I only have the mechanical fan working to cool it down.
  4. Aug 23, 2019 at 11:04 AM
    Couple things to check before....:
    1) radiator cap not holding pressure allowing hot expanded coolant to escape
    2) thermostat installed incorrectly or sticking
    3) clog in the system resulting in over heat
    4) replace the electric fan
    JKBob 25 and Rey88[OP] like this.
  5. Aug 23, 2019 at 11:15 AM
    Rey88
    Temecula California
    93 XJ 4 door
    Thanks man I’ll check em all out
  6. Aug 24, 2019 at 12:40 PM
    Sometimes when coolant is replaced an air pocket can develop in the cooling system, which can cause an overheat. Driving the vehicle up and down steep hills can push it out. After following steps 1-4 above.
    aggrex and Rey88[OP] like this.
  7. Aug 24, 2019 at 12:47 PM
    Rey88
    Temecula California
    93 XJ 4 door
    Awesome thank you!
    just got a new thermostat today and electric fan
