Couple questions- new Jeep TJ
Discussion in 'Wrangler TJ (1996-2006)' started by carnut169, Jun 25, 2018.
  1. Jun 25, 2018 at 11:51 AM
    carnut169
    carnut169 [OP] New Member
    Sean
    1998 Wrangler Sport
    Picked up a new used TJ and I was told it needed a new motor. I’m suspect though bc it’s clean as a whistle and doesn’t appear to have been off road.
    The wires have been removed from the plugs- need to know which goes to
    Which.
    Also, there is a block of wires that come from the firewall on the passenger side- maybe attached to the Ecu. There is a solid pink wire that’s been cut- any idea why?
    I’ll be doing a compression test tonight.
  2. Jun 25, 2018 at 12:09 PM
    what model year engine trans etc...
    Yes that is the PCM,
    I would TRY the key trick to get codes and maybe we will ID that wire otherwise a search of wiring diagrams....
  3. Jun 25, 2018 at 12:16 PM
    carnut169
    Sean
    1998 Wrangler Sport
    It’s a 2008 sport. 4.0/ 5 speed. What’s the key trick?
  4. Jun 25, 2018 at 2:31 PM
  5. Jun 25, 2018 at 3:06 PM
    Welcome! If the key trick works...great, otherwise some car parts stores like Advance Auto offer free scans or you can invest in one as basic models are not too expensive anymore.
