Cowl drain
Discussion in 'Off-Topic Discussion' started by Jeepgirl2007, May 23, 2019.
  1. May 23, 2019 at 7:02 AM
    Jeepgirl2007
    Jeepgirl2007 [OP] New Member
    Collette
    Jeep wrangler Sahara 2007
    I recently cleaned out the cowl drain to stop the leaking inside my jeep and the side panel under the windshield had tape over the hole. Do I need to replace the tape and if so what do I use
    TJ_abuser likes this.
  2. May 23, 2019 at 7:06 AM
    Hello Collette, welcome from Oklahoma.
    Tape over the hole? Sounds like someone had already tried to keep it from leaking into the cab, but I don't have a Wrangler so I can't confirm if this was factory or not.
    Sorry, but again welcome to Jeeps.net
  3. May 23, 2019 at 7:29 AM
    Welcome to the site!
  4. May 23, 2019 at 7:42 AM
    Welcome @Jeepgirl2007 ...despite what they say about jeeps...tape covering a hole is probably DIY. But if it stops a particular leak I'm good with it. Plumbers putty would last longer.
    TJ_abuser and JKBob 25 like this.
  5. May 23, 2019 at 7:49 PM
    Agree....Gotta be a DIY fix. Play Doe works just as well. And it comes In various colors. :cool:...:p. Just kidding.
    If the duct tape works keeping Jeep dry. I would consider an alternative as @aggrex suggested..
