Crazy gremlin
Discussion in 'Wrangler JK (2007-2017)' started by Patriotjk, May 28, 2019.
  1. May 28, 2019 at 9:07 AM
    Patriotjk
    Patriotjk [OP] New Member
    Joel
    2010 jk
    my 2010 gets ck engine lights all the time I clear them out a few days later a new one will pop up completely unrelated I think. Not super impressed with my first Jeep and my girls 07 Cherokee is worse. Anyway this is a 3.8 145k new heads in the last few hundred miles but the check engine light thing was happing before also
  2. May 28, 2019 at 9:11 AM
    Welcome @Patriotjk ...post up the codes for evaluation. Erasing them before making repairs keeps them popping up like garden mushrooms.
  3. May 28, 2019 at 9:15 AM
    Hello Joel, welcome from Oklahoma.
  4. May 28, 2019 at 9:40 AM
    Why not leave the light ON let the system collect info and look at it?
    Start by copying ALL codes, it is best to use a SCANNER as the key trick is limited.
    Daughters jeep should be priority, thats my thinking anyway.
    Add any modifications (powertrain) recent work and added or replaced parts ie chips, proms, programmers.
    PS : you do have a scanner. Can it display live data?
  5. May 28, 2019 at 9:43 AM
    Thats done business first....
    Welcome to the forum, :jeepwave: hope we can help .
    Where is home - north - south - west? just for fun and details, GTG
  6. May 28, 2019 at 1:58 PM
    Welcome from Texas
  7. May 28, 2019 at 6:25 PM
    Patriotjk
    Joel
    2010 jk
    I am using a scanner last code it gave me was p0404 cleared drove 130 miles hasn’t came back before that was intermittent miss ran fine cleared that have driven 500 miles not back a bit back I had a small vacuum leak code cleared that never came back. Still a little miffed how a Jeep with under 140k needed new heads both warped must of been that way when I bought someone had replaced gaskets. And I have the typical heat problem which I’ve replaced everything and still crappy heat
  8. May 28, 2019 at 6:25 PM
    Patriotjk
    Joel
    2010 jk
    And thanks guys for the welcome
  9. May 28, 2019 at 8:31 PM
    Welcome to the site!
