Cvt transmission
Discussion in 'Patriot' started by Guanocray, Sep 27, 2018.
  1. Sep 27, 2018 at 5:37 PM
    Guanocray
    Guanocray [OP] Member
    Joan
    09 Jeep Patriot
    I have an 09 Patriot and I am going to change the fluid in my cvt transmission and I can't find the pan bolt torque specs anywhere! Any suggestions as to where I can find them?
  2. Sep 27, 2018 at 7:00 PM
    Welcome! My recommendations are to make sure the pan flanges are flat, clean off the old gasket and use Mopar CVT fluid. Not sure of the exact pan bolt torque specs for the CVT trans but following a torque sequence of increasing pressure might be recommended to prevent crushing the gasket.
    Guanocray[OP] likes this.
  3. Sep 27, 2018 at 7:12 PM
    Guanocray
    Joan
    09 Jeep Patriot
    Thank you. Everyone says you have to take it to a dealer, but that can be very expensive. Think I'm going to do it myself,and if I mess it up then I can justify spending the money at the dealership lol
  4. Sep 27, 2018 at 7:37 PM
    I found this:
    https://www.youtube.com/watch?v=7BL3QR6kncw
    And this:
    https://www.youtube.com/watch?v=WJvtelXJkuk
    https://www.youtube.com/watch?v=n26vix08IDU
    Bob, Guanocray[OP] and aggrex like this.
  5. Sep 27, 2018 at 10:11 PM
    Guanocray
    Joan
    09 Jeep Patriot
    Wow thank you so much!
  6. Sep 28, 2018 at 7:32 AM
    Glad to help! Now, lets see a picture of your Jeep :)
    Guanocray[QUOTED][OP] likes this.
  7. Sep 28, 2018 at 9:00 AM
    Per AllData the oil pan bolts are 70in. lbs... INCH pounds. ;)
    And should take about 1.2 hours, add .2 if you have a skid plate.
    Guanocray[OP] and chris4x4 like this.
  8. Sep 29, 2018 at 8:07 AM
    That's only about 6 lbs/ft. Is that right?
  9. Sep 29, 2018 at 8:41 AM
    That 70 in.lbs translates to 6 lb-ft. DIY whenever possible but on some CVT trans the service could be challenging with issues such as using the correct CVT fluid, over or under-filling the CVT and potential leaks.
  10. Sep 29, 2018 at 4:06 PM
    Guanocray
    Joan
    09 Jeep Patriot
  11. Sep 29, 2018 at 4:07 PM
    That's a great color!
  12. Sep 29, 2018 at 6:40 PM
    Guanocray
    Joan
    09 Jeep Patriot
    Thank you. She's old but I love her
