DAMN IT !!!! NO BRAKES
Discussion in 'Wrangler TJ (1996-2006)' started by Adam39601, Sep 2, 2018.
  1. Sep 2, 2018 at 4:20 PM
    Adam39601
    Adam
    2001 jeep wrangler sport
    Ok here we go i changed my front rotors calipers and pads an flex lines. I blead the lines pumped the lines till no air In lines on both sides. When I push on brakes I get pressure, but when I turn on the motor I loose pressure help please.and the break light stays on with a full reservoir
  2. Sep 2, 2018 at 5:56 PM
    Oh man...I hate brakes, but subbed to find an answer.
  3. Sep 2, 2018 at 9:04 PM
    Might want to check the brake fluid level in the master cylinder then look for external leaks from brake lines(rusty?/weeping?), calipers and wheel cylinders. Brake fluid contaminated? Hopefully its not the master cylinder as it can be worn and leaking.
  4. Sep 3, 2018 at 5:56 AM
    dougbbbb
    dougbbbb Well-Known Member
    Are the calipers on the correct side? Bleeders should be at the highest point. Also try gravity bleeding the front calipers sometimes air gets back in the rear cylinder by leaving the valve open too long.
    Doug
    JKBob 25, Awrench and aggrex like this.
  5. Sep 3, 2018 at 8:17 AM
    Adam39601
    Adam
    Have checked an done all of that still no psi when motor is on
  6. Sep 4, 2018 at 10:13 AM
    brake light stays ON - yellow or red light?
    Do you have ABS?
  7. Sep 4, 2018 at 2:52 PM
    Adam39601
    Adam
  8. Sep 4, 2018 at 6:03 PM
    Drd88
    Drd88 Active Member
    Dan
    Silver creek new york
    79 cj 5/2000 wrangler
    360amc Borg Warner t-18 trans
    Check proportioning valve
  9. Sep 4, 2018 at 7:08 PM
    Subbed too. Numerous fixes posted up top. Drastic and sudden loss of pressure. Usually a sign of a leak some where. My experience....Usually at a wheel cylinder. Check for fluid on the inside of tire and rim. Just a thought.
    dougbbbb and aggrex like this.
  10. Sep 7, 2018 at 6:01 AM
    Did you by any chance change install a new master cylinder too, if so did you bench bleed it before installing it? Are you vacuum boost or Hydraulic (Im not sure which year is which) Look for a vacuum leak if vacuum boosted.
  11. Sep 7, 2018 at 12:32 PM
    Did you bleed the back brakes too?
    Still sounds like you have air in the lines to me.
    The Brake warning light is likely the proportioning valve, either it has failed or is sensing a bias in pressure. This is why I asked if you bleed the rear brakes as well.
    If not try bleeding the rears also and see if it helps your pedal pressure and turns the brake warning light off.
    How are you bleeding your brakes?
    I have great success doing it by myself by loosening the bleeder valve, putting a hose over it and then putting the other end of the hose in a small container of brake fluid. Slowly pump the pedal 3-5 times. Hand tighten the bleeder before removing the hose, remove hose and tighten bleeder valve with wrench.
    Start are Right Rear, then Left Rear, Right Front and then Left Front.
    Keep brake fluid topped off during the process.
