Dash cluster
Discussion in 'Cherokee' started by sparkplug, Oct 9, 2019.
  1. Oct 9, 2019 at 6:18 PM
    sparkplug
    sparkplug [OP] New Member
    Have a 1999 jeep cherokee 4.0 liter inline 6. after driving about 30 minute instrument cluster will stop working.no oil presser no temperature no speedometer no voltage no gas but i can hlt a railroad track or a bump in road and everything will start back working.replace clock-spring seem to fix problem but it back.when this problem occur.horn will work.but that all.no cruise control.
  2. Oct 9, 2019 at 7:37 PM
    Gauge cluster connection is a common issue, you can try smacking the top of the dash or pressing on the top corners of the cluster.
    Could take the dash apart and check the connections and/or reseat them.
  3. Oct 10, 2019 at 6:12 AM
    what he said -- the issue is the connector for dash/instrument cluster - often just cleaning with 'deoxit' type product, google the issue there is likely a video on replacing connector.
    NO: 08-15-99
    SUBJECT: Erratic, Intermittent Cluster Operation/Intermittent Air Bag Warning light.
    DATE: May 21, 1999
    THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN NUMBER 08-20-98 REV. A, DATED OCTOBER 2, 1998, WHICH SHOULD BE REMOVED FROM YOUR FILES AND NOTED IN THE BOUND TECHNICAL SERVICE BULLETIN BOOK, PUBLICATION NUMBER 81-699-99003. THIS IS A COMPLETE REVISION TO THE PROCEDURE.
    OVERVIEW:
    This bulletin involves installing a repair harness containing a revised instrument cluster connector.
    SYMPTOM/CONDITION:
    Some vehicles may exhibit an intermittent illumination of the air bag warning light or an intermittent tachometer or speedometer drop out. An Airbag Electronic Control Module (AECM) fault code -"No Cluster CCD BUS " message will be present.
    Here is the repair:
    1. Disconnect the negative battery cable.
    2. Remove the instrument cluster using the procedures outlined in the appropriate servicemanual.
    3. Inspect the male terminals of pins 1 & 2 on the instrument cluster connector labeled CNB. The oxidation will appear as gray or black lines or marks on the terminals. If any signs of oxidation are present, remove them by gently scraping the terminals with a small flat bladed screw driver until the oxidation is gone. Use of a magnifying glass may be helpful. Use caution when performing this operation. Do not apply excessive force to the terminals to avoid bending them or damaging the cluster or terminals. Do not use a sharp tool, knife or sand paper, which could remove the protective plating from the terminals. Do not use any cleaner other than p/n 04856975. Other chemical cleaners could damage the instrument cluster.
    4. Clean the male terminals with Electrical Contact cleaner, p/n 04856975. Apply the cleaner sparingly holding the cluster with the connector facing down to avoid excessive amount of cleaner from entering the cluster.
    5. Remove the green cluster connector from the bracket.
    6. Using wire cutters, remove the instrument cluster harness connector from the harness. Remove only the connector containing the BUS circuit. This connector is labeled CBA on the cluster. Cut the wires as close to the insulator as possible.
    7. The new connector must be soldered onto the harness. This operation requires a technician who is skilled at soldering to avoid a cold solder joint. Position the harness and align the wires with the patch harness, matching the color codes match the main wire colors.
      NOTE: THE XJ INSTRUMENT PANEL CONTAINS ONE MORE CIRCUIT IN THIS CONNECTOR THAN THE TJ. CUT THE UNUSED WIRE CLOSE TO THE CONNECTOR ON TJ MODELS.
    8. Stagger cut the main harness and patch harness wires so that the solder joints will be 1/2 inch apart. Remove 1/2 inch of insulation from the wires. The new harness will have a dark blue with no tracer. This will mate with a dark blue wire with a green tracer on TJ and with a dark blue wire with a white tracer on XJ.
    9. Slide a piece of heat shrink tubing over the wires and twist the wires together for each respective circuit.
    10. Solder each circuit using rosin core solder. Be sure to heat the wire enough to allow the solder to melt when it comes in contact with wire. Do not use acid core solder.
    11. Position the heat shrink tubing over the solder joints and shrink the tubing using a heat gun.
    12. Install the connector to the bracket.
    13. Install the instrument cluster.
    14. Connect the battery cable.
    15. Verify correct operation of the cluster.
    Here is a picture to help you out:
    The part you will need is:
    05016261AA
  4. Feb 3, 2020 at 5:37 PM
    Scurvy_Dan
    Scurvy_Dan New Member
    Part Number 05016261AA is no longer available!
    Any ideas?
