De-badging
Discussion in 'General Jeep Discussion' started by Robare, Nov 30, 2019.
  1. Nov 30, 2019 at 8:12 AM
    Robare
    Robare [OP] Member
    -r
    Minnesota
    2019 Jeep Cherokee Trailhawk
    Hey Guys,
    New Jeep owner here. I’m thinking of removing the raised badges on my Cherokee Trailhawk where they do not sit in a body well. Does anyone have experience with this & how does it look? My intent is to do it early so as to not have to do a ton of buffing to remove the under-badge grime and adhesive. Recommendations for methods & cleansers would be helpful too.
    Thanks in advance,
    -r
  2. Nov 30, 2019 at 8:19 AM
    Clean_93
    Clean_93 Member
    Levi
    Red 5.2 93 jeep grand cherokee laredo
    Any badging is pretty easy to remove with fishing line and a heat gun. Fashion some handles for the line or use your fingers. Then heat the area until warm to the touch. Get the line back there and shimmy behind the badge until it's gone. Eraser wheel then that sweet 3m perfectz it and youd be good.
    Hope that helps
  3. Nov 30, 2019 at 11:29 AM
    Pretty much what @Clean_93 said. Use a little lube on the fishing line to help it cut thru the adhesive. I used WD-40 with good-ish results.
  4. Nov 30, 2019 at 1:05 PM
    As mentioned start with WD-40 before using harsher solvents that can damage the finish
  5. Nov 30, 2019 at 2:13 PM
    Robare
    Robare [OP] Member
    -r
    Minnesota
    All good advice, Thanks!
    Besides removing the adhesive once the badge is off, is there any buffing or polishing needed for the paint underneath?
  6. Nov 30, 2019 at 2:56 PM
    Unless the badging has been on for many years and sun-baked on no extra buffing should be needed.
  7. Nov 30, 2019 at 5:32 PM
    Robare
    Robare [OP] Member
    -r
    Minnesota
    That’s my hope. Thanks for your input!
    -r
  8. Nov 30, 2019 at 7:00 PM
    Awesome advice. I just learned me some thing new. Nice @Clean_93 .
    Clean_93 likes this.
  9. Dec 12, 2019 at 6:36 PM
    Viaqua
    Viaqua Problem Child
    Joe
    Port St. Lucie Florida
    3" Teraflex Lift, 4.10 Gears, Teraflex Steering Dampener, Smittybilt 9500 Winch, AEG Rock Crawler Bumpers, AEG Rock Sliders, AEG Fender Liners, Rugged Ridge Steel Fenders, Sway Bar Disconnects, 20" XF Off Road Rims, 33x12.5 Rockstar Mud Tires, LED Light Bars, K&N Filter
    I used waxed Dental Floss to remove the Badge and Jeep letters on the grille. Used 91% Rubbing Alcohol to remove the glue then waxed the areas.
    Clean_93 and JKBob 25 like this.
  10. Dec 13, 2019 at 9:05 AM
    Robare
    Robare [OP] Member
    -r
    Minnesota
    Thanks, good advice.
