Delrin Bushings and EZ out door pins
Discussion in 'General Jeep Discussion' started by aggrex, May 10, 2018.
  1. May 10, 2018 at 10:46 PM
    aggrex [OP] Well-Known Member
    Delrin door hinge bushings replace corroded or worn bushings. QT has the complete kit to upgrade your bushings to make door removal simplified with less chance for damage while doing the rocking shaking door dance when struggling to get the doors off. EZ stainless steel door pin guides help guide putting the doors back in.
    gently tap and remember to protect the paint
    minor corrosion for two yr old jk
    clean and lube the hinge
    Delrin bushing should press in with minimal force
    use emory cloth to remove corrosion
    ez on pins can stay on if desired
    slow careful ratcheting
    chris4x4 and Billy1234 like this.
  2. May 11, 2018 at 3:32 AM
    Billy1234
    Billy1234 Well-Known Member
    William
    1997 XJ 2 door
    None yet
    I need this in my life!
    OFFGRID likes this.
