Dies at high speeds
Discussion in 'Wrangler TJ (1996-2006)' started by Byeandle, Aug 24, 2018.
  1. Aug 24, 2018 at 6:46 AM
    Byeandle
    Byeandle [OP] New Member
    2002 Wrangler X 4.0
    My jeep will drive all around town day after day with no problems. When I get on the highway, the minute it reaches 60mph it dies like theres no fuel. It throws no engine light. It sits for a minute, cranks right back up and I have to go slow to get off the highway but will drive around town like nothing ever happened. Its getting frustrating. Its a 02 4.0 X. It's recently gotten new thermostat, waterpump, radiator, head gasket, 5th piston and rings, fuel pump, tps, crankshaft sensor. Was going to replace the cam shaft and map sensor but decided to see if anyone had any ideas before spending more money. Thanks in advance.
  2. Aug 24, 2018 at 6:53 AM
    SmittyJeeper
    06 wrangler 4.0 6speed
    Have you rechecked fuel pressure since this problem started?
  3. Aug 24, 2018 at 7:06 AM
    Byeandle
    2002 Wrangler X 4.0
    Yes, that's the first thing i did and the pressure is good.
  4. Aug 24, 2018 at 7:15 AM
    SmittyJeeper
    Does it also die if you rev the engine at lower speeds like putting it in 2nd gear and up to 3k rpms or is it specific to going 60 mph?
  5. Aug 24, 2018 at 7:24 AM
    Byeandle
    2002 Wrangler X 4.0
    I hadnt revved it while driving but parked in the driveway we've revved it up to 3k rpms and it doesnt die
  6. Aug 24, 2018 at 7:53 AM
    Given the specific speed at which the problem occurs leads me to believe it is related to the VSS (Vehicle Speed Sensor). It's part of a 5v sensor system that communicates with the ECM (computer). I know if it fails completely it can keep the vehicle from even starting.
  7. Aug 24, 2018 at 8:15 AM
    Byeandle
    2002 Wrangler X 4.0
    Ill replace that and see what happens.
  8. Aug 24, 2018 at 8:38 AM
  9. Aug 24, 2018 at 9:17 AM
    you can have codes stored and NO check eng light- (CEL). the codes will not always turn on a CEL.
    if you had a scanner we could look at data for a reading not ideal ie fuel trims.
    SmittyJeeper;s suggestion is good -
