Difference in engine wiring harness?
Discussion in 'Grand Cherokee' started by parrishpd8015, Jun 9, 2020.
  1. Jun 9, 2020 at 10:36 PM
    parrishpd8015
    parrishpd8015 [OP] New Member
    steven
    white 03 grand cherokee
    03 grand cherokee laredo engine wiring harness i have found 3 wiring harnesses but all 3 are W in the 5th letter of the vin#. Mine is an X. What is the difference?
  2. Jun 10, 2020 at 4:52 AM
    Welcome @parrishpd8015 ...options and accessories can change even within a build year so check with Jeep parts department for definitive answer to your question on the wiring harness. It could turn out to be an unused connection in your JGC
  3. Jun 10, 2020 at 9:12 AM
    W=4wd, X=2wd
    I imagine the engine harness should be same/similar since the main difference between the W and X is further down the drivetrain, given they both have the same engine.
    And while I can't confirm for sure if the harness is anything like the older Jeep harnesses even if it doesn't have a particular accessory it may still be wired for it.
  4. Jun 10, 2020 at 10:29 AM
    Whenever I have to go for dealer parts it helps to have the vin number written down on a separate piece of paper to hand to the parts guy. Also at the auto parts stores. Buying parts using the make, model, and year is no more.
