Dist. Pickup Coil to Ignition Module
Discussion in 'CJ' started by cbdeajr, Feb 21, 2017.
  1. Feb 21, 2017 at 6:33 AM
    cbdeajr
    cbdeajr [OP] New Member
    Cecil
    1979 CJ7
    none
    Looking to see where I can purchase the wiring harness that goes between the Distributor Pickup Coil and the Ignition Module for a 1979 CJ7 with a 304 engine?
  2. Feb 21, 2017 at 6:49 AM
    I have a '79 CJ7 with I6, I have been unable to find any wiring harness seperates; only the whole harness from centech, and painless. I have just rewired what I had to with my own supplied wiring from the autoparts house. The best thing I ever did for my jeep second to fuel injection was to ditch the ignition module, coil, and distributor, and replace it all with a 1 wire HEI distributor with integrated coil (basically trading Ford for Chevy electronics) Runs a whole lot better with this setup. I cut the wiring to the ignition module and ran the hot over to the new distributor and your done.
  3. Feb 22, 2017 at 12:22 PM
    cbdeajr
    Cecil
    1979 CJ7
    none
    where could I get the plugs. 1 is female 3 and the other is 4 slots.
  4. Feb 22, 2017 at 8:48 PM
    That is junk yard, or purchase whole wiring harness. In a pinch you can crimp on the flat blade to each wire individually and at the other end crimp on the speaker connector and then plug them in individually.
    [​IMG][​IMG]
  5. Feb 22, 2017 at 8:51 PM
    You might find one on ebay?
