DIY Suspension & Axle Upgrade
Discussion in 'Wrangler JK (2007-2017)' started by aggrex, May 29, 2025.
  1. May 29, 2025 at 7:34 PM
    aggrex [OP] Well-Known Member
    FedEx delivered my Dynatrac 44/60 axles in a large wooden box 700 lb. Modified a pair of HF dollys to safely move the big heavy axles under the Jeep. The motorcycle jack was handy to get the axles onto the dollys.IMG_6675.jpg
    MTgeezer, JKBob 25 and LYFZGOOD like this.
  2. May 29, 2025 at 7:46 PM
    Metal Cloak 3.5” Game Changer and HD steering kit. 22 ton jack stands probably overkill but the wide base means stability.
  3. Nov 5, 2025 at 5:45 PM
    It’s been awhile for updates on my Jeep project but life issues, mandatory vacations and honey-do-lists have diverted my attention elsewhere. But I finally have some progress to share. The front axle & lift kit are installed but nothing is torqued down yet. Work on the rear axle & lift kit has begun and should be easier than the front. New 1350 drive shafts to match the Dynatrac axles will be ordered. The motorcycle jack has been handy for controlling the heavy axle during removal. Could have used taller jack stands the next time HF has a sale. IMG_7874.jpg IMG_8015.jpg IMG_8014.jpg IMG_8019.jpg IMG_8020.jpg
  4. Nov 5, 2025 at 5:53 PM
    For anyone contemplating a project with super heavy axles consider combining two HF 1000 lb dolleys to custom fit the heavy Dana 60 axle resulting in ease of movement and safety. Even the old Dana 44 was a heavy beast.
    Note: old drive shaft refused to break loose. Didn’t want to waste anymore energy so it leaves with the old axle. IMG_8018.jpg IMG_8012.jpg
  5. Nov 5, 2025 at 6:08 PM
    Short list of tools I used to make things easier:
    M18 impact wrench (mid)
    M12 impact wrench
    Long wrenches 18,21,22,24
    Sockets 8,13,18,21,22,24,36,1-1/4
    Daytona floor jack
    Pittsburgh motorcycle jack
    Jack stands(3,6 ton) larger the better
    Breaker bar
    Penetrating oil
    Measuring tape
    X large adjustable wrench for adjustable arms
    Gloves
    Lighting
    Mask, goggles, work clothes (no sandals)
    5lb slide hammer
    Puller
    Torque wrench
    Foam pads
  6. Nov 19, 2025 at 3:57 PM
    The rear axle install was simple compared to the front axle. Metal Cloak provides starting length recommendations for each adjustable component: control arms, track bar, tie rod and drag link. My expectations are to be successful performing the alignment: toe, castor pinion angle.IMG_8236.jpg
    LYFZGOOD and JKBob 25 like this.
  7. Nov 19, 2025 at 4:06 PM
    With all new suspension components and the Dana 60 axle it was discouraging to re-install the rusty rotors, parking brake parts. I ordered a new parking brake assembly and added the big brake kit. IMG_8224.jpg IMG_8237.jpg
  8. Nov 19, 2025 at 4:09 PM
    Miscellaneous pics of axle prep before installationIMG_8198.jpg IMG_8196.jpg IMG_8197.jpg IMG_8222.jpg
  9. Nov 19, 2025 at 4:10 PM
    Wife said the magic words: tires are too small ;)IMG_8238.jpg
    LYFZGOOD, MTgeezer and JKBob 25 like this.
  10. Nov 20, 2025 at 11:50 AM
    MTgeezer
    MTgeezer Well-Known Member
    John
    55 CJ 3B
    OK, what did you get for gearing? Inquiring minds want to know---- Nice axles/lift.
    aggrex[OP] likes this.
  11. Nov 20, 2025 at 3:37 PM
    Thanks…..with the 6 speed MT I went with 4.88 Eaton lockers which I hope works well with 35s or 37s. Appreciate any tips from your vast experiences that will help point me in the best direction moving forward.
    MTgeezer[QUOTED] likes this.
  12. Nov 20, 2025 at 7:19 PM
    only time in your life it’s ok for ur wife to use “small” in a sentence referring to you or something you own :rofl::rofl:
    JKBob 25 and aggrex[QUOTED][OP] like this.
  13. Nov 20, 2025 at 8:20 PM
    MTgeezer
    John
    55 CJ 3B
    I think you nailed it. At least for 35's.
  14. Nov 21, 2025 at 12:50 PM
    IMG_8263.jpg IMG_8264.jpg The Dynatrac big brake kit (gen 1) uses oversized rotors F&R with a matching oversized caliper brackets. Simple upgrade that uses the OEM calipers and although the brake pads are proprietary the OEM pads can be substituted in a pinch. IMG_8251.jpg
  15. Nov 21, 2025 at 4:18 PM
    Rear rotor is 14” and the front is 13”. Other users of this system state to expect rear pads to wear out before the front which may depend IMG_8266.jpg IMG_8267.jpg upon how you drive. Luckily OEM pads fit too for less money
  16. Jan 5, 2026 at 4:45 PM
    Got shafted in the front and rear! :anonymous:
  17. Jan 5, 2026 at 4:49 PM
  18. Jan 5, 2026 at 4:51 PM
    OEM 10 year old 600 CCA battery finally failed. Replacement Interstate H7 850 CCA AGM was a tight fit. IMG_8651.jpg IMG_8657.jpg it’s 1.5” wider.
  19. Jan 5, 2026 at 8:53 PM
    was a tight fit.
    THAT’S WHAT SHE SAID :rofl::rofl:
    JKBob 25 and aggrex[OP] like this.
