Door lock problem using key fob after TIPM replacement
Discussion in 'Electrical' started by ktm, Feb 8, 2019.
  1. Feb 8, 2019 at 8:29 AM
    ktm
    ktm [OP] New Member
    2013 Jeep Gr. Cherokee Laredo Cy.
    Started 2013 Grand Cherokee in subfreezing temps. Wiper went on continuously, interior lights out, no turning signals, 3-4 warning lights on dashboard.
    Replaced TIPM and did hard reset, everything went fine except doors.
    Placing hand on driver's door should open only that door. It opened the other 3 doors and left driver's door locked. Placing hand on front passenger's door opened all door except the driver's door.
    All doors will open and lock with armrest button on driver's side. Passenger armrest button opens all door except driver's.
  2. Feb 8, 2019 at 8:38 AM
    First thought owners manual*. programming the EVIC...
    Next a scanner to check codes and work the issue.
    There will be a test later....
    Be sure to turn horn with door lock/open to OFF, flash lights only.
  3. Feb 8, 2019 at 11:22 AM
    ktm
    ktm [OP] New Member
    Did another hard reset.
    Turned horn off and ran scan- No fault codes.
    Same problem.
  4. Feb 8, 2019 at 11:48 AM
    hard reset? disconnecting battery and connecting cables to discharge ?
    Stop doing this, it erases all info, and then codes, learned and stored info and monitors status will be gone.
    Will your scanner read all codes not just P series, "B" series and "U" .
    Was there a EVIC configuration for door lock open modes?
