Door Nuts
Discussion in 'Wrangler JK (2007-2017)' started by w1lso, Apr 3, 2017.
  1. Apr 3, 2017 at 7:45 AM
    w1lso
    w1lso [OP] Member
    Matt
    2012 Red Jeep Wrangler Unlimited Sport
    Steel Fender Flares, Warn Stubby Bumper, 35's Toyo ATII Extreme.
    Does anyone know if they make different sizes in the door hinge nuts? I got me some motorcycle mirrors for going doorless and they work great in the wind at high speeds but the thread barely sticks out the bottom of the hinge. I was hoping the door nut would work but I need one a tad bigger.
  2. Apr 3, 2017 at 8:15 AM
    I'm guessing you mean longer. Check a local hardware store. They carry all sorts of sizes of fasteners
  3. Apr 3, 2017 at 11:22 AM
    w1lso
    w1lso [OP] Member
    Matt
    The thread on the mirror is a tad bigger. Just wondering if they make a bigger hinge nut or is that just a Jeep thing?
  4. Apr 3, 2017 at 11:49 AM
    Take the mirror to any hardware store. They have sizing tools to measure the size and thread count so that you can then choose the correct nut for the job.
    w1lso[OP] likes this.
  5. Apr 3, 2017 at 12:36 PM
    w1lso
    w1lso [OP] Member
    Matt
    Ok I'll try that.
  6. Apr 3, 2017 at 6:20 PM
    Great idea to repurpose a set of motorcycle mirrors. Another idea is to modify the "bend" in the metal to extend the threads deeper into the hinge. Some hardware stores may have a threaded extension if its a common size.
  7. Apr 3, 2017 at 10:43 PM
    w1lso
    w1lso [OP] Member
    Matt
    Didn't know that was a option, I'll check into that. Thanks
  8. Apr 4, 2017 at 7:10 AM
    You might be able to size it to the OEM nut using a tap. You can get a Tap & Die set at Harbor Freight for a fair price.
  9. Apr 4, 2017 at 10:48 AM
    w1lso
    w1lso [OP] Member
    Matt
    I need to check with some guys I work with, they may be able to do that. I didn't know that was a thing lol... but that's a great idea. Thanks for the help guys!
  10. Apr 8, 2017 at 8:09 PM
    w1lso
    w1lso [OP] Member
    Matt
    Well guys I got my mirrors fixed up. Went to a machine shop and the guy there grinded the stem down, bout a quarter inch, where the washer stopped so I could move the washer up. Just gotta sand em and paint em and they'll be good to go.
