Driveshaft?
Discussion in 'Other Jeep Vehicles' started by 525JoeyYJ, Aug 12, 2017.
  1. Aug 12, 2017 at 12:15 PM
    525JoeyYJ
    525JoeyYJ [OP] Well-Known Member
    Joe
    1989 Jeep Wrangler YJ
    Hello all! So what do y’all do when you’re converting a short bed 2.5l Comanche to 4X4 and the rear driveshaft can’t be used from a donor vehicle like the tranny and the axle could because the 4.0l sets further back than the 2.5l, so the driveshaft from That is too short?
  2. Aug 12, 2017 at 12:16 PM
    525JoeyYJ
    Joe
    The same with the front?
  3. Aug 12, 2017 at 7:09 PM
    Custom length balanced driveshafts are in your future unless you can find some from the 80's.
  4. Aug 13, 2017 at 12:44 PM
