Electrical ...head light and turn signals
Discussion in 'Wrangler YJ (1986-1995)' started by Kikindirt, Jun 8, 2019.
  1. Jun 8, 2019 at 2:54 PM
    Kikindirt
    Kikindirt [OP] New Member
    Thomas
    1988 wrangler
    I've replaced head light switch on the dash signal relays..checked and cleaned fuse box.....checked all bulbs ..replaced steering column..with same..I still think I got issues in the column....need some new ideas....help
  2. Jun 8, 2019 at 3:23 PM
    Kikindirt
    Thomas
    1988 wrangler
    Happy face;)got the turn signal issue resolved...wiring on sterring column....head light low and high beam now is left to reslove
  3. Jun 8, 2019 at 3:34 PM
    Good on the turn signal issue. Use multimeter to check for voltage at switch, relay and head lights. Sometimes the problem is with the ground wires. Check, clean, tighten and ensure no corrosion. Others may chime in for tips as it's a relaxing weekend. Your not alone in jeep duty LOL.
    Kikindirt[OP] and Bob like this.
  4. Jun 9, 2019 at 3:40 PM
    Kikindirt
    Thomas
    1988 wrangler
    Thanks I'll sure be digging more into it
