Replacement for burned Wrangler YJ gauge cluster dash
Discussion in 'Wrangler YJ (1986-1995)' started by Jeepdood, Jun 29, 2018.
  1. Jun 29, 2018 at 5:38 AM
    Jeepdood
    Jeepdood [OP] Active Member
    95 wrangler
    None yet
    95 Wrangler YJ
    Yesterday I had a short somewhere
    Causing a small fire behind the gauge cluster. Center part of dash.
    Does anyone know where I can get a replacement for this?
  2. Jun 29, 2018 at 10:45 AM
    kind of vague on what is needed-
    look in a jeep part manual and search part numbers google,
    contct a junk yard specializing in jeeps,
    search your local junk yard...
    Post here and some one might have a source.
  3. Jun 29, 2018 at 11:40 AM
    Finding that "short somewhere causing a small fire" sounds concerning
  4. Jun 29, 2018 at 12:21 PM
    I did not think to address the cause - hoping it is corrected -
    @aggrex is right that is the priority -
    what caused fire?
  5. Jun 29, 2018 at 1:34 PM
    I purchased a OEM cluster set on eBay for mine. Bought all new light bulbs at Oreilly's.
  6. Jun 29, 2018 at 1:36 PM
    The cluster is a self contained unit with one plug feeding all of it. Hopefully replacing it will fix your problem.
  7. Jun 30, 2018 at 11:20 AM
    2oldjeeps
    2oldjeeps Well-Known Member
    98 and 2000 xj's 99wj
    junkyard part?
    OFFGRID likes this.
