Engine dies while driving
Discussion in 'Cherokee' started by bobr, Mar 23, 2017.
  1. Mar 23, 2017 at 9:23 AM
    bobr
    bobr [OP] New Member
    1999 Grand Cherokee - 98,000 miles 4.0L
    3 times for the last month the engine will just cut out while driving then I can restart with no problem, there seem to be no unusual conditions for this to happen, check engine lite does not come on - my scanner does not show a code - anyone with similar problem?
  2. Mar 23, 2017 at 9:43 AM
    Welcome! Are you able to duplicate the issue, or is it just random?
  3. Mar 23, 2017 at 10:16 AM
    bobr
    random - no symptoms or indication of when it will happen
  4. Mar 23, 2017 at 3:52 PM
    I would check to make sure why and all vacuum lines are in good condition and not broken, disconnected, or cracked
  5. Mar 27, 2017 at 9:35 AM
    Threerun
    Threerun Member
    1998 Jeep Cherokee 4.0
    OME 2-3"
    I had that ghost on an old Grand Cherokee. Happened all the time- especially when turning (odd). I replaced the fuel filter and the problem went away for a year or more.
    Then the ghost came back. Replaced the fuel filter again and it didn't help- at least not immediately. Then out of the blue the problem went away. It really irked me.
  6. Apr 16, 2017 at 1:29 PM
    Shaw92
    Shaw92 New Member
    2000 jeep grand Cherokee limited
    If you don't get a check light when it happens. I'd try changing the crank shaft position sensor. Mine did that and once I replace the fuel filter n fuel pump n the sensor it hasn't given me any problems since
