Engine keeps running after key is turned off
Discussion in 'Wrangler JK (2007-2017)' started by Awesometimes, Aug 11, 2017.
  1. Aug 11, 2017 at 7:42 PM
    Awesometimes
    Awesometimes [OP] Member
    Greg
    94 Wrangler yj
    Stock
    I need some help my friend just as in yesterday bought a 2010 Wrangler. When he turns the key off the engine keeps running. It will stop after a couple of minutes or if you turn the key back on it will shut off after about 20 seconds.
    Any ideas what to check or replace
  2. Aug 12, 2017 at 6:25 AM
    SmittyJeeper
    06 wrangler 4.0 6speed
    I've never seen that on a jeep before but it sounds like the ignition switch is bad. They are fairly easy to change and around $60 from a napa store. I would start there if it were me.
  3. Aug 12, 2017 at 9:14 AM
    Awesometimes
    Greg
    94 Wrangler yj
    Stock
    Thanks I will check that
  4. Aug 12, 2017 at 5:23 PM
    Jeep_Guy
    Jeep_Guy Active Member
    Jeep Wrangler Sport unlimited
    Your jeep is possesed lol
  5. Aug 12, 2017 at 6:27 PM
    Awesometimes. It's not knocking and pinging like it's trying to shut down ? Or does it keep running as if you never turned the key off?
  6. May 25, 2023 at 3:38 AM
    Jmuir92
    Jmuir92 New Member
    2007 jeep wrangler
    lift wheels tires bumpers winch
    Ran across this thread after searching the issue im having. What did you figure out with the issue? Im having the same issue that started over the weekend
  7. Oct 5, 2024 at 12:04 PM
    Itsnotacuallynotmine
    Itsnotacuallynotmine Such a stupid typo
    John
    Orange crush 2013 wrangler Sierra
    8" R.C. lift alpine hu with kicker components covering the rest of the system
    I'm having the same issue. It just continues to run even after the key is removed. The dash will sit down like normal but the engine didn't miss a beat like the key never left the run position. Steering wheel will lock but yeah. I'm lost on what to do
