Engine won't turn over after overheating incident
Discussion in 'Cherokee' started by Jennyjenn76, May 29, 2018.
  1. May 29, 2018 at 11:36 AM
    Jennyjenn76
    Jennyjenn76 [OP] New Member
    2001 Jeep Grand Cherokee Laredo
    Yesterday I was stuck behind a parade and my jeep overheated, I replaced the radiator, which was clogged and also the relay under the passenger headlight. I went to start it and it cranks but won't turn over. Everything is turning and what not. What could it be?
  2. May 29, 2018 at 12:00 PM
    If you have the inline 6 it is the 0331 head which is prone to cracking. So likely cracked and possibly warped head and a blown head gasket.
    Have you checked the oil to see if there is any coolant mix in it?
  3. May 29, 2018 at 1:10 PM
    I would imagine it would have to be pretty severe for it to not start however with no oil/coolant intermix I would lean towards something else causing the no start issue.
    I would run a compression test on it though as there is a good likely hood of a cracked/warped head and blown head gasket. And if so, fix it and then address the no start issue. It is not a hard job, would be a good learning experience if you have never done it before. The head is pretty heavy so you might want help lifting it off.
  4. May 30, 2018 at 7:00 AM
    I am confused - happens alot :)
    You turn key engine spins? that is cranking
    you turn key engine spins? that is defined as turning over.
    So the engine spins but will not START - am I correct? thats a NO START condition.
    Then I would get codes.
    check engine oil as suggested looking for evidence of coolant, Next will be BASICS.
    Is there spark?
    Is there fuel?
  5. May 30, 2018 at 7:06 AM
    Jennyjenn76
    So I had a mechanic come and the motor is blown and cracked head and other things. She is on her way to Harry's. All started with the blown fan relay, I didn' repair it fast enough.
  6. May 30, 2018 at 7:13 AM
    Wow sorry - the worst case scenario :(
    I am always the optimist.
  7. Jun 1, 2018 at 8:23 AM
    Jenny, let us know how it goes
  8. Jun 1, 2018 at 10:00 AM
    2oldjeeps
    2oldjeeps Well-Known Member
    98 and 2000 xj's 99wj
    as i drive i constantly monitor temp and oil gages.
  9. Jun 1, 2018 at 10:26 AM
    Too funny. Me too. Especially that temp gauge. It was always climbing until I replaced the Radiator. Now I watch out of habit.
