Excessive gas tank pressure
Discussion in 'Wrangler TJ (1996-2006)' started by SJfamilyjeep, Jul 24, 2019.
  1. Jul 24, 2019 at 12:40 PM
    SJfamilyjeep
    SJfamilyjeep [OP] Member
    2001TJ and 2016 JKUR
    On my 01 TJ I have a codes 0441 0442 0449 (faulty gas cap and faulty solenoid). When I take off the gas cap (factory) I there is a lot of air pressure escaping. I make sure to open it daily or else it builds up and I don't need a bomb in front of my house. I'm thinking a bad purge valve bad that's stuck closedAnyone else had this issue or had ideas?
  2. Jul 24, 2019 at 1:42 PM
    2001 wrangler and I will guess a 4.0L engine.
    The codes will likely have a P in front of them - there are also prefixes B, C, U, etc and sounds anal but could.
    I am wondering if the sound is not pressure but VACUUM as air rushes into tank.
    P0441-EVAP PURGE FLOW MONITOR
    P0442-EVAP LEAK MONITOR MEDIUM
    this one below I need to check out.
    P0499-NVLD Canister Vent Valve Solenoid Circuit
    PS you are using a SCANNER to retrieve all codes? important.
  3. Jul 24, 2019 at 2:42 PM
    For starters I am not sure
    Is it possible that a bad gas cap could have set off those codes? It is of course the easiest thing to check.
  4. Jul 24, 2019 at 6:09 PM
    As mentioned inspect the gas cap and charcoal canister
