Fan switch problem
Discussion in 'Electrical' started by JeepJunky, Dec 12, 2018.
  1. Dec 12, 2018 at 5:41 PM
    JeepJunky
    JeepJunky [OP] New Member
    99 jeep wrangler 4.0
    I have a 99 wrangler. I have replaced the fan switch twice this year. Just replaced again. Same problem, fan runs for awhile then shuts off. Any suggestions?
  2. Dec 13, 2018 at 8:08 AM
    A few other components to check, wiring is a known issue some connectors may melt - causing issues- confirm the connector at resistor is good, tight no corossion.
    At the HAVC module in dash (control panel) same check of elec connectors.
    How comfortable are you with A DVOM, and a wiring diagram?
    Do you have AC? IF we need to get a diagram.
    PS on a reread - what switch did you change twice?
  3. Dec 13, 2018 at 10:30 AM
    Also, Does the fan come back on after a while on its own, or does it never come back on.
  4. Dec 13, 2018 at 3:34 PM
    Welcome! Just for clarity did you have any positive results after changing the fan switch the first time? Over heating issues?
