Fender flare mounting
Discussion in 'Wrangler TJ (1996-2006)' started by The4x4Guys, Apr 24, 2019.
  1. Apr 24, 2019 at 8:26 PM
    The4x4Guys
    2018 Black JLUR
    When I was removing the faded factory flares from the TJ, several of the screws were inserted into captive nutserts in the body. Several others were attached to a piece of black plastic backing up to the inner fender. When removing several of these that were behind the inner fender liner, there was no apparent way to grab them so they fell into the inner fender liner.
    1) is there a way to easily retrieve them?
    2) if no, what can be used if I decide to re-install the factory flares after cleaning them up? and how do I get these backing pieces back there.
    3) is there a mounting kits readily available to replace all those rusty screws?
    I am torn between new wider flares (Bushwacker or Rugged Ridge) versus cleaning these up with Forever Black and/or spraying them with the bedliner product I am thinking of using for the body tub.
  2. Apr 25, 2019 at 6:00 AM
    for your project - let me know if helpful. Page 346 - till you learn to navigate.
    good karma , I hope
    JKBob 25 and DustStorm4x4 like this.
  3. Apr 25, 2019 at 7:53 AM
    The4x4Guys
    2018 Black JLUR
    Many thanks, that is perfect. Good Karma indeed!!
  4. Apr 25, 2019 at 6:08 PM
    DustStorm4x4
    DustStorm4x4 Well-Known Member
    04 LJ
    Wow tons of info. Super helpful for basically anyone with a TJ. Thanks.
  5. Apr 27, 2019 at 6:11 AM
    Got one of those for an 05 LJ ?
  6. May 15, 2019 at 4:08 PM
    FishinSam
    FishinSam Member
    Alberta, Canada
    1999 Gold TJ Sahara 4.0L
  7. May 15, 2019 at 4:09 PM
    FishinSam
    FishinSam Member
    Alberta, Canada
    Got one for a 99 TJ or are exactly the same until 06?
