Foam sleeve on bows
Discussion in 'Wrangler TJ (1996-2006)' started by JC TJ, Nov 15, 2018.
  1. Nov 15, 2018 at 8:36 AM
    JC TJ
    JC TJ [OP] New Member
    Hi all! First post so bear with me. Searched for what to call/ how to find replacements for the little foam sleeves on the bows for the soft top. There are three per side two small ones and one larger one. I have a shredded large one.
    Thanks!
    JC
  2. Nov 16, 2018 at 9:42 AM
    Welcome aboard! Have you checked out Quadratec? They carry alot of those replacement parts.
  3. Nov 16, 2018 at 9:58 AM
    Welcome! I've only had hard tops so soft toppers will chime in. Would foam insulation for water pipes fit? If so they could be reinforced or UV protected with a wrap? Just a thought.
  4. Nov 16, 2018 at 10:38 AM
    JC TJ
    Looked at Quadratec an couldn't find em. I considered the pipe wrap but the bows are smaller than 1/2 inch pipe. Still might go that route and make em fit. I'm sure it'll be cheaper than OE parts anyways.
    JC
  5. Nov 16, 2018 at 11:34 AM
    What is the diameter of the bars you need the foam for?
    You can get foam insulation for 1/2" pipe.
    The insulation is pretty thick though.
