For Sale: 6.0 GM Vortec Powered 2016 Jeep Wrangler Unlimited Rubicon
Discussion in 'Wrangler JK Marketplace (2007-2017)' started by Gypsyboy, May 26, 2025 at 2:27 PM.
  1. May 26, 2025 at 2:27 PM
    Gypsyboy
    Gypsyboy [OP] New Member
    2016 Wrangler Unlimited Rubicon
    47,200 miles -- Never driven in winter by the previous owner or myself, always stored in an enclosed building. This is obvious when looking at the underside of the Jeep, the rust-free body, and the dent and scratch-free body.
    GM 6.0-liter L96 Vortec V8 from a 2016 GMC Denali 2500 with 2,000 miles on the engine at time of install, Dyno tuned with a HP tuner
    GM 6L80E six speed automatic transmission purchased NEW for the conversion
    GM ECM control module -- (2) 0BD ports for diagnostics -- (1) for GM drivetrain and (1) for Jeep
    No cats, all other emissions and fuel system is correct, monitor for the catalyst is not set because of the lack of cats, shows no codes or warning lights
    Mo-Tech conversion kit (Las Vegas, NV)
    (2) large bar and plate coolers for engine oil and transmission fluid
    Original 3.6L Pentastar radiator and brushless PWM cooling fan, controlled by the GM ECM, runs at normal operating temp no matter what the ambient temperature is and what elevation it is at. I drove this jeep from near Detroit, Michigan to the Colorado/ New Mexico border at 75-80 mph with the cruise control set and it runs excellent and tracks great.
    K&N air filter
    Dana 44 axles, Tru-Lok locking differentials, 4.56:1 gearing, Tera Flex differential covers
    Auxiliary rear locker switch engages rear locker in 2-wheel drive or 4-wheel drive High
    OEM locker switch engages front and rear lockers in 4-wheel drive Low
    High Pinion front axle
    Dana Spicer front driveshaft
    Evo manufacturing coil springs (3-inch lift)
    Bilstein shocks
    AEV high steer kit and geometry correction bracket
    Tera Flex forged track bars and adjustable rear control arms
    ball joints replaced November 2021
    Jeep Hard Rock bumpers
    Jeep Hard Rock hood
    2018 Rubicon brakes, 2 piston fronts
    AEV swing-out rear tire carrier
    (5) BF Goodrich All Terrain KO2 35 X 12.5 X 17 tires with excellent tread left -- less than 5,000 miles
    (4) Mopar 17-inch bead lock wheels (1) Mopar 17-inch bead lock capable wheel (beauty rings included)
    keyless entry
    heated front seats
    power connection under rear seat and 110 inverter
    2-inch rear receiver hitch and plug for trailer wiring connection
    (2) DB Link A-pillar off road lights controlled by rocker switch in cab
    Truck-Lite LED headlights
    reverse back-up camera
    Mopar LED fog lights controlled by rocker switch in cab
    The hard top and doors have never been taken off of this Jeep.
    Bikini top included (never used)
    The interior is in great condition.
    Asking $46,000. Located in Trinidad, Colorado
    Number 3.jpg Number 9.jpg Number 18.jpg Number 23.jpg Number 30.jpg Number 32.jpg Number 34.jpg Number 43.jpg Number 57.jpg Number 70.jpg
