Front axles
Discussion in 'Wrangler TJ (1996-2006)' started by LYFZGOOD, Aug 3, 2019.
  1. Aug 3, 2019 at 3:10 PM
    LYFZGOOD [OP] members
    OK guys and gals have a question I replaced my universal joints in my front axles,what did I do wrong I have very little oil coming out of my axle tubes?
    98 tj 120,000 miles.
  2. Aug 3, 2019 at 3:34 PM
    You are not supposed to have any oil coming out of the axle tubes as there is supposed to be a seal inside of them to prevent that from happening.
    JKBob 25, Bob and Harleymick like this.
  3. Aug 3, 2019 at 3:51 PM
    Where is the seal? When I pulled the axle out there was nothing else. Is the seal close to the rear end ? back towards the middle ?
  4. Aug 3, 2019 at 3:54 PM
    Could I have too much oil in the rear end? It shouldn’t be in the axle tube. Right??
  5. Aug 3, 2019 at 8:56 PM
    The front axle has seals closer to the center on the inside of the tubes where as the rear needs the oil to travel out to lube the bearings,
  6. Aug 4, 2019 at 7:41 AM
    It’s a 98 TJ No bearing until the hub assembly no way for the oil to travel from the rear end down the axle tube to the hospital
  7. Aug 4, 2019 at 8:09 AM
    Ok found the problem. Over filled the rear end. Drained Out some oil how. Now we’re good thanks for the help
  8. Aug 4, 2019 at 9:10 AM
    Glad you found the issue. Thought the general axle refill process was to pump axle fluid into the fill hole until it trickled out. Axle seals are usually near the pumpkin. Sometimes there are axle shaft guide rings within the axle tube.
  9. Aug 5, 2019 at 10:53 PM
    Thanks. I didn’t have it level when I filled it my bad
