Fuel gauge not working on a 79 CJ7
Discussion in 'CJ' started by Frisco, Jul 8, 2021.
  1. Jul 8, 2021 at 6:13 PM
    Frisco
    Frisco [OP] New Member
    1979 cj7 golden eagle
    I currently own a 1950 cj3a and a 1979 cj 7 . The fuel and temp have never worked and both have been replaced with no improvement. My question is the temp gauge uses 5 volts does the fuel use 5 volt or 12 volt. I have 1 amp 5 volt regulators that could be used to power the temp gauge and if the fuel gauge requires 5 volts a second regulator could be used. I would like the temp to work the fuel at this point is optional. (I can still walk or write down the mileage)
  2. Jul 31, 2023 at 11:16 PM
    MBC
    MBC MBC
    Ernest
    Fort Lauderdale
    79 CJ 97 TJ 06 TJ
    A little bit of everything.
    I feel like all fuel gushed can run on 12v. I’ve done other gas tanks and there’s a way to ground out the sensor to see if it’s getting voltage. Then diagnose the sender or the gauge.
  3. Aug 11, 2023 at 6:37 PM
    Hbomb
    Hbomb New Member
    Henry
    1979 CJ5
    Typically with fuel sending units, the sending unit is the ground and the change in the resistance dictate full or empty.
    if you take the wire off of the sending unit the gauge needle will bury past full and ground it to a good ground and it will go to empty, if my memory serves me correctly. So if your gauge is getting power and not faulty, this method will isolate the problem and tell you if its a faultily sending unit or not. Hope this helps
    You can also use ohm meter and test the sending unit and see if the resistance changes an you move the arm of the sending unit up and down.
