Gas gauge
Discussion in 'Wrangler YJ (1986-1995)' started by Adrian550, Jun 3, 2019.
  1. Jun 3, 2019 at 7:53 AM
    Adrian550
    Adrian550 [OP] New Member
    Adrian
    Jeep wrangler yj
    My gas gauge hasn't been working in a while it moves from empty to full when I turn the car on but it stays at full, then it moves from full to empty when I turn the car off, it stays at full and I'm having to calculate my gas by the amount of miles I drive. You think this is a gauge problem or do I need to replace the fuel sending unit?
  2. Jun 3, 2019 at 8:19 AM
    tell us about yur jeep - year, model. etc.
    We can get a diagnostic plan for you...
    It will likely be a wiring or sending unit i doubt a gauge issue.
    Adrian550[OP] likes this.
  3. Jun 3, 2019 at 9:36 AM
    Adrian550
    Adrian
    Jeep wrangler yj
    It's a 1990 jeep wrangler yj 4.2L I6. 2 door. Sahara sub model.
  4. Jun 3, 2019 at 11:49 AM
    I think the tan wire to sender may be shored to ground, OR the sending unit in tank is bad, try unplugging and checking wire, volts, ohms, continuity, ground - then leave off see if gauge stays at E or F.
  5. Jun 3, 2019 at 9:46 PM
    Adrian550
    Adrian
    Jeep wrangler yj
    Thanks! I will check those
