Gas goes in slowly
Discussion in 'Wrangler YJ (1986-1995)' started by jfaxon, Feb 25, 2018.
  1. Feb 25, 2018 at 9:54 AM
    jfaxon
    jfaxon [OP] New Member
    Jimbo
    1989 Jeep Wrangler Islander
    I have a 89 Wrangler with 6inch lift. When I go to put gas in it ,it wants to spit it back out.took 10 mins. To put 15 dollars in.
  2. Feb 25, 2018 at 10:54 AM
    Welcome to the site! I don't have much input on this, but someone should chime in shortly.
  3. Feb 26, 2018 at 2:45 PM
    I have same problem with both my Cj and Yj. I believe it's a design flaw. I can only pump on low setting. Anybody else have a fix?
  4. Feb 26, 2018 at 4:03 PM
    I have *knock on wood* never had this issue but have seen that it is most commonly attributed to a clogged evap system or fuel tank vent valve.
    I don't know when Jeep started it but I have seen the TJ guys complain that a check ball that rides on rails in the filler neck getting stuck.
  5. Feb 26, 2018 at 6:35 PM
    Welcome to the forum @jfaxon.
    I believe another member had this same issue. I'll have to see if I can find the thread. If memory serves me. It's as OFFGRID said. Its a design flaw. Just bring a magazine when you to fill up dude. Loll.
