GAS PROBLEM
Discussion in 'Cherokee' started by CMW 91, May 2, 2020.
  1. May 2, 2020 at 3:37 PM
    CMW 91
    CMW 91 [OP] New Member
    Need help 83 cherokee 4.2 auto if it sits for any length of time it won't start it will crank but no fire further investigation shows no gas in the glass filter before the pump gauge shows half tank where's the gas
  2. May 2, 2020 at 9:14 PM
    There could be a bad fuel pump or cracks in the fuel hoses. One location for a cracked fuel line is the hose right out of the tank. After checking all the fuel lines, check for fuel line pressure.
  3. May 2, 2020 at 11:05 PM
    CMW 91
    Thanks I'll give the whole thing a once over or twice
  4. May 3, 2020 at 7:28 AM
    As mentioned check fuel line pressure. Since its an '83 its probably best to inspect/replace any rubber lines and fuel filter too.
