Getting code for throttle position sensor
Discussion in 'Grand Cherokee' started by 2000Laredo, Aug 28, 2021.
  1. Aug 28, 2021 at 12:20 PM
    2000Laredo
    2000Laredo [OP] Member
    Ronnie
    2000 Grand Cherokee Laredo
    2Inch lift sitting on 275 75r Mickey Thompson Deegon 38s.
    Replaced and got the code for the tps.any suggestions.have done reset ecu. Totally confused on what happen.thinking bought a faulty one maybe.
  2. Aug 28, 2021 at 7:33 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    What engine? I know there's no way to adjust the TPS on the 4.0 HO engine. You can test it with a multimeter.
    With ignition on, check TPS output voltage at sensor wiring harness center terminal. At idle, output voltage should be about .2 or less. Gradually open throttle plate. Voltage should increase as throttle plate is opened. At wide open throttle, output voltage must be less than 4.8 volts. If voltages aren't right, make sure 5-volt input and ground wires between TPS and engine controller are okay.
    If wiring is ok, but voltages are out of range, you probably got a faulty TPS.
  3. Aug 29, 2021 at 1:58 AM
    2000Laredo
    Ronnie
    Gonna try that today.hoping I bought a bad one. Keep u updated thanks man.
  4. Aug 29, 2021 at 10:08 AM
    What is the code? Just post ALL codes system shows.
    What issues symptons are you addressing?
    Is the AIRBAG light ON ?
    Confirm a 2000 WJ GRAND cherokee and a 4.0L engine?
    Bob and Groundfault like this.
  5. Aug 29, 2021 at 11:02 AM
    2000Laredo
    Ronnie
    P0121 was the code.so I put the old one back in no code.was gonna test new one but tried old one again.i think it's faulty.and yes my air bag light is on.is it related.thanks
    Ps yes confirmed
  6. Aug 29, 2021 at 11:48 AM
    Groundfault
    Tim
    @Awreta is asking all of the right questions. P0121 and air bag light can be linked through a faulty clockspring.
    Disconnect battery, unplug clockspring harness, reconnect battery. Clear codes and see if P0121 code returns wit new sensor installed.
  7. Aug 29, 2021 at 11:59 AM
    2000Laredo
    Ronnie
    Where is the clock spring harness.sorry new to this just thought it would be simple.airbag light has been on before this problem.no code with old tps.im in my jeep now acually.no check engine. Air bag light is.
  8. Aug 29, 2021 at 12:23 PM
    Groundfault
    Tim
    Clockspring is in steering wheel. Harness runs down steering column.
    If your tps code doesn't come back, problem solved. May not even be related to air bag light. If tps code pops up again, you might want to try disconcerting clockspring and see if code will clear without changing tps.
    Hope it behaves! Keep us posted.
  9. Aug 29, 2021 at 12:27 PM
    2000Laredo
    Ronnie
    Ok .just got home no check engine.will update you guys thanks A Million.
  10. Aug 31, 2021 at 12:52 PM
    2000Laredo
    Ronnie
    All good on tps.it was faulty.running much stronger.airbag light this weekend.thanks for all the help .
