Grand Cherokee overland bad brakes
Discussion in 'Grand Cherokee' started by bdsjsajk, Jul 10, 2021.
  1. Jul 10, 2021 at 10:44 AM
    bdsjsajk
    bdsjsajk [OP] New Member
    bob
    jeep overland
    I have a 2014 overland. I have 45k miles on it. We have had to have the brakes worked on 4 times already and they are still not right. I have replaced the rotors and pads and calipers along with hoses 3 times. The brakes are still running soft and not doing full contact with rotors. Can't get a handle on this. Don't know if it's the abs system or proportion device? Not sure what it is. Jump in and give me some opinions! In less than 7k I will have to repair or replace them again if no answers. Also I have the life time warr. on it and jeep will not do crap. Thank you.
  2. Jul 10, 2021 at 12:39 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    Could be air trapped in the ABS modulator. Most modulators have bleed screws. Modulators without bleed screws require a scan tool to activate the ABS solenoid while bleeding brakes. Only other idea I have is a bad master cylinder.
    Stuff like this keeps me awake at night, so keep us posted when you find solution.
