Hardtop side glass removal YJ
Discussion in 'Wrangler YJ (1986-1995)' started by Mxdad777, Aug 4, 2018.
  1. Aug 4, 2018 at 4:55 AM
    Mxdad777
    Mxdad777 [OP] Member
    1987 Wrangler YJ
    i picked up a used hardtop for my YJ and am going to paint it. I’ve got it stripped down, but not sure how to remove the side glass. It looks like it’s a combo seal/sealant and not just a seal. Does anyone have any experience in removing the side glass on a YJ?
    Thanks in advance for and help.
  2. Aug 4, 2018 at 8:40 AM
    Welcome to the site! I think its attached with an adhesive. You might want to contact a glass company and see what they recommend, or just take extra time to mask it off.
  3. Aug 4, 2018 at 9:02 AM
    Welcome! I second Chris's comment as removing glass to paint would not be my choice. I'm sure it's glued on pretty well. What's the plan for the hardtop? Solid panel in place of the glass? Scratches? Get it tinted.
  4. Aug 4, 2018 at 9:52 AM
    Mxdad777
    1987 Wrangler YJ
    The glass is in great shape I was just wanting to remove it for ease of painting. The fact that it is glued in, I’m just going to mask it. I talked to an auto glass place today and they want $150 to reinstall and said it will be a pain to remove. Masking tape it is.
  5. Aug 6, 2018 at 7:20 AM
    Be sure to post pictures to show us how it turns out :)
  6. Aug 6, 2018 at 8:11 AM
    Mxdad777
    1987 Wrangler YJ
    Well, after doing a little more research, I found that the glass is glued in but the rubber seal isn't really a seal as much as its a rubber trim piece. I grabbed it and pulled on it and it came out from around the window. The rubber is kind of like a "T" molding. I can now tape off the glass and paint the entire top and then replace the rubber with new trim. I'll post pics when I'm done.
  7. Aug 6, 2018 at 7:01 PM
    Mxdad777
    1987 Wrangler YJ
    DCF73A63-6718-442B-B253-CF557FEA1B6E.jpg 2F384848-561A-41D8-B211-0B38C89A3F66.jpg After much research I decided to texture the top and I used Dupli-Color Rocker Guard Coating for the texture. It laid down a nice even light texture. I followed that up with SEM Trim Black paint with a medium reducer at a 1:1 ratio. I’m very happy with the way it turned out. Below is a pic along with a close up to show the texture.
    Now to get all the rubbers replaced and the rear hatch glass put back on. Then it’s onto the doors. I’ll be painting them blue to match the Jeep.
  8. Aug 6, 2018 at 7:50 PM
    Nice PRO job on refinishing the hard top. I'm finding minor defects on my newer hardtop that I have to ignore or use a quick dash of paint on scrapes or chips.
  9. Aug 7, 2018 at 6:53 AM
    boondoc89 Well-Known Member
    Always replace your rubbers :devil:
  10. Aug 7, 2018 at 7:18 AM
    That looks great!
  11. Aug 19, 2018 at 9:10 PM
    Mxdad777
    1987 Wrangler YJ
    Finally finished the doors and got everything put back together. The color isn’t an exact match, but I didn’t want to mess with blending and so I went with it. I don’t think anyone will notice unless they look close. I’m also a believer in the vinyl paint dye. A local upholstery shop told me about it and my local auto paint store had nothing but great things to say about it. I figure if it holds up on seats, it should hold up on door panels. I guess time will tell. All in all I’m very happy with my new to me hardtop and doors.
  12. May 7, 2020 at 7:31 AM
    SrdjanDV
    SrdjanDV Active Member
    Srdjan
    Great job, looks nice. Congrats!!
  13. May 7, 2020 at 4:46 PM
    Wow August 20-2018 I guess it’s never to
    late for congrats. So congratulations!!!
