Hardtop texture or smooth???
Discussion in 'General Jeep Discussion' started by Mxdad777, Aug 4, 2018.
  1. Aug 4, 2018 at 10:48 PM
    Mxdad777
    Mxdad777 [OP] Member
    1987 Wrangler YJ
    I picked up a used hardtop for my YJ and had to repair a few blemishes in it. Since the repaired spots ended up smooth, I sanded the entire top smooth starting out with 220 and ended with 800 wet sanding. My thought was to paint the top smooth but now I’m having second thoughts. Do these hardtop look okay smooth or should I texture it like they come from the factory?
    Second question is, if I texture it first, what do I use? I’m going to top coat it with a black satin finish but what do I use under the finish coat for the texture?
    Thanks in advance for any help.
  2. Aug 5, 2018 at 5:38 AM
    JoeInOh
    JoeInOh Active Member
    Joe
    Ohio
    Are you painting it to match your jeeps color? If you are, I would go smooth. Otherwise I would consider PlastiDip and a Glossifier which also adds uv protection.
  3. Aug 5, 2018 at 9:31 AM
    Mxdad777
    1987 Wrangler YJ
    My Jeep is blue and the top I’ll be painting satin black. I’m just not sure if I want to texture it or paint it smooth.
  4. Aug 5, 2018 at 9:51 AM
    RubiconFreedom
    Nor-East Uni-Stat
    if you're thinking of textured, it would behoove one to think Monster Liners as this product comes in a multitude of colors.
  5. Aug 5, 2018 at 12:41 PM
    JoeInOh
    Joe
    Ohio
    I used Monster Liner for the floor and (instead of carpet) in my Vanagon Westfalia. The stuff is great. Like @TrailBadger mentioned they have a ton of colors - including some pretty crazy shades. Definitely recommend.
  6. Aug 5, 2018 at 12:42 PM
    JoeInOh
    Joe
    Ohio
    If you are doing satin finish and you have already sanded it down - I would just go with smooth. My opinion.
  7. Aug 5, 2018 at 3:02 PM
    boondoc89 Well-Known Member
    I'd put a truck bed liner on it to give it texture and some extra protection from the sun and trail mishaps. I've actually been thinking about doing that to the hardtop on my jeep to be honest.
