Head bolt sealant
Discussion in 'Cherokee' started by XjJoeXj, Jan 2, 2018.
  1. Jan 2, 2018 at 7:04 AM
    XjJoeXj
    XjJoeXj [OP] Member
    99 xj
    Stock
    Hi guys new here and new to working on these jeeps . I have been twisting wrenches since i was a kid but have never done anything like a head gasket before . I recently replaced the cracked head on my 99 4.0 . Reinstalling the new head from clearwater last night . Like a dope i put the first bolt in #11 slot with never seeze on it finger tight . I had it all clean with the head off. Fearing the liquid thread sealant wouldn't work with the now never seezed hole i used Teflon tape as some suggested . I also noticed afterward that my torque wrench was set at 120 instead of 110 for 13 of the 14 bolts . I was freezing and rushing through the process i suppose . #11 is deff torqued to 100 like specs say . I'm reading that the Teflon tape was a no no . Should i pull all the bolts and put new gasket , retorque to 110 with the same new bolts i just put in or leave it as it is and run it . Thanks in advance . Joe from NJ
  2. Jan 2, 2018 at 7:45 AM
    Welcome aboard! I would think it best to pull the bolts, and re install correctly, but hopefully someone with morw knowledge an post up.
  3. Jan 2, 2018 at 12:37 PM
    XjJoeXj
    XjJoeXj [OP] Member
    99 xj
    Stock
    I think I'm just going to pull #11 throw some liquid thread sealant on it and reinstall .. after asking a guy at work who has far more experience then i, he said i should be fine at 120. I'm hoping anyhow. I'm afraid if i loosen one at a time and retorque it to a lower value ill waste the gasket that is already compressed to the higher value
  4. Jan 2, 2018 at 2:22 PM
    2oldjeeps
    2oldjeeps Well-Known Member
    98 and 2000 xj's 99wj
    torq wrench could be off 10 % anyway huh
    JKBob 25 and XjJoeXj[OP] like this.
  5. Jan 2, 2018 at 7:23 PM
    Welcome to the forum XjJoeXj. Jersey here too. Cold....yeah. 12° sucks. 24 today feels like a sauna. Lolll.
    Never replaced a head on a Mopar motor. Did several on chevys. As @2oldjeeps stated. Most torque wrenches are off to some degree. And, you should be fine over torquing by 10#. Not recommended. But it should be fine. You are correct. If you retorque at a lower #. You may up up haveing issues. Never use Teflon tape. Your resistance will be off, as well as your torque #. Use tape on plumping. Thermostat housing and such where torque # isn't so critical.
    We have some very knowledgeable members here that I'm sure will be able to add more in put. Stay warm dude.
  6. Jan 3, 2018 at 5:23 PM
    You should be good. re torque that #11 with never seize. You can also use petroleum jelly. Both will do the same thing.
  7. Jan 4, 2018 at 2:46 PM
    XjJoeXj
    XjJoeXj [OP] Member
    99 xj
    Stock
    Excellent guys . Thanks for the replies. I took #11 out and retorqed it with the loctite 592 ( i think it was ) high temp thread sealer . I can be a little ocd at times lol . I love the jeep & don't want to screw it up . I was going to finish her up this evening but was busy plowing today with this "cyclone bomb" or whatever the news labeled it .. seemed like a normal old snow storm to me :rain:. Anyway thanks a million guys for putting my mind at ease . . I'm sure ill be back sooner or later with some more questions
  8. Jan 4, 2018 at 2:56 PM
    XjJoeXj
    XjJoeXj [OP] Member
    99 xj
    Stock
  9. Jan 4, 2018 at 2:59 PM
    XjJoeXj
    XjJoeXj [OP] Member
    99 xj
    Stock
    That's her i scored it for $500 . Was running like a top till i noticed the coolant disappearing .. next is some 31s and a 2" lift
  10. Jan 4, 2018 at 3:13 PM
    Welcome! Great score @500 and fixed just in time for some snow-fun for some folks.
  11. Jan 4, 2018 at 6:07 PM
    Not to hijack the thread. Yeah...we got some snow today. Spent half the day digging out.
  12. Jan 5, 2018 at 6:52 PM
    Great start for that Jeep. I had a 2000 for years. 2"lift with 31s.
