Heater core outlet pinched shut..
Discussion in 'Cherokee' started by TinyInkognegroT, Sep 24, 2019.
  1. Sep 24, 2019 at 12:54 PM
    TinyInkognegroT
    How do I fix or replace quickly ?
  2. Sep 24, 2019 at 1:06 PM
    TinyInkognegroT
    Couldn't I just plug it from both ends and continue driving ? Or does it play a part of the engine cooling system?
  3. Sep 24, 2019 at 1:11 PM
    You can by-pass it by routing the heater hose back to the engine, eliminating the heater core all together.
    That is how mine is currently until I can get time to replace the heater core.
    Not a quick job.. the book time with A/C is 5.5 hours not including the evac/recharge of the A/C system.
  4. Sep 24, 2019 at 8:07 PM
    Thought the leak you had was in a different location. Who mangled that section of the core outlet? Could try some plumbing hack ideas using shark-bites or compression fittings onto a slightly smaller pipe....etc LOL
  5. Sep 28, 2019 at 10:58 AM
    TinyInkognegroT
    How would I go about that exactly? This is the current setup I have now...PHOTO_20190928_125451.jpg PHOTO_20190928_125539.jpg
    I plugged off the end on the intake and the heater core outlet, is exposed and leaks water out as I drive. I have to put in 3 gallons of water almost every time I have to drive. The outlet doesn't seem to be pinched as I thought it was because water still shoots out from it. Should I bypass it as you say or throw the hose on both ends as it should be?
  6. Sep 28, 2019 at 6:15 PM
    Hose from thermostat port to water pump port.
    aggrex and TinyInkognegroT[OP] like this.
  7. Sep 28, 2019 at 6:20 PM
    TinyInkognegroT
    Great, thanks for the picture reference.
  8. Sep 28, 2019 at 6:30 PM
    TinyInkognegroT
    FB_IMG_1569720525600.jpg Is this all one hose ?
  9. Sep 28, 2019 at 7:12 PM
    Yes it is one of the hoses that goes to the heater core.
  10. Sep 29, 2019 at 5:31 AM
    TinyInkognegroT
    the hose is on the right side or the left side, if I'm looking from the front of the engine?
  11. Sep 29, 2019 at 6:25 AM
    I don't remember which one of the heater core hoses I used, I just took one of them and connected each end to where the heater core hoses attach to the engine.
  12. Sep 29, 2019 at 7:06 AM
    TinyInkognegroT
    I know the pinched side (left from front of engine) shoots water out of the heater core, so I'm assuming that's the outlet and the other side is the inlet, as it takes water in to the heater core... I'm just trying to make it to where the water isn't shooting out of the pinched side because it's getting water on my valves and my throttle body connections plus I have to keep adding 3 gallons of water every time I drive. So if you can when you get a chance, can you double check on yours and let me know exactly which ends the hose needs to be attached to in order to keep water cycling through my engine ?
  13. Sep 29, 2019 at 9:11 AM
    TinyInkognegroT
    I'm just now starting to understand what you mean... You have no hoses on the inlet and outlets on the firewall. You have your heater core hose ends attached to the two water connections on the engine block.
  14. Sep 29, 2019 at 9:12 AM
    TinyInkognegroT
    If that pinched outlet is pouring water out then it's not really too pinched off and maybe I can throw hose on it and have it running as normal ? Or should I just bypass it? I'm not really worried about not having heat right now
  15. Sep 29, 2019 at 2:11 PM
    Thats why I suggested trying to repair (un-pinch) the damaged section as best as possible. Make it round as possible and cut off the jagged edge with copper pipe cutter (use cutter correctly). Carefully clamp a hose on the un-pinched section and don't crush it again. Check out some plumbing fittings or couplers if needed. Keeping warm this winter in the JGC would be a priority >4me>lol
  16. Sep 30, 2019 at 3:45 PM
    TinyInkognegroT
    aggrex[QUOTED] likes this.
  17. Sep 30, 2019 at 4:46 PM
    Secure and protect that hose from any hot or sharp surfaces otherwise there might be a coolant shower in the forecast.
