Heavy duty tire carrier...need help.
Discussion in 'General Jeep Discussion' started by peacelove911, Mar 11, 2017.
  1. Mar 11, 2017 at 2:59 PM
    peacelove911
    peacelove911 [OP] Member
    Bobby
    2013 sunset orange 2 door soft top
    3" lift, off road lighting, winch
    I just bought a 2013 2 door Wrangler withh 33's but the Jeep had the stock carrier and tire on it. I just bought a Smittybuilt heave duty carrier and it alone weighs a ton. with the carrier, rim and 33, will it "sag" my back end? Jeep has a lift....pictured.
  2. Mar 11, 2017 at 5:55 PM
    peacelove911
    Bobby
    Really need input my friends...please help me out. Thanks.
  3. Mar 11, 2017 at 8:31 PM
    You should be fine. If it says at all, it shouldn't be much. If it does happen to sag, you can get a small 1/2" spacer for the springs.
  4. Mar 11, 2017 at 8:32 PM
    Fwiw, I'm running an aftermarket tire carrier, and 33's and it didn't say.
  5. Mar 12, 2017 at 6:22 AM
    peacelove911
    Bobby
  6. Mar 12, 2017 at 12:03 PM
    Should be fine...you did the right thing upgrading the stock tire carrier to handle the 33s
  7. Mar 12, 2017 at 1:33 PM
    peacelove911
    Bobby
    Thank you...
