Hello Folks, thanks for having me.
Discussion in 'CJ' started by Davis, Apr 2, 2017.
  1. Apr 2, 2017 at 7:00 AM
    Davis
    Davis [OP] New Member
    78 cj-7
    None
    I have a 78 cj7 and I'm looking to install a body lift but bolts are just turning. HELP
  2. Apr 2, 2017 at 8:31 AM
    Welcome! Are the nuts to the body bolts visible?
  3. Apr 2, 2017 at 8:48 AM
    Welcome! Not too suprising due to the age of the vehicle but I'm sure you used the usual steps (PB blaster, heat,etc) or impact wrench. Like mentioned above access to the nuts will be key. Are all the bolts just spinning or just a few?
  4. Apr 3, 2017 at 9:21 AM
    The fun begins! Drill, good heavy chisel, and a 3lb sledge hammer.
