Hello from Lynnwood, WA
Discussion in 'New Member Introductions' started by cj5fanatic, Jan 23, 2021.
  1. Jan 23, 2021 at 8:48 AM
    cj5fanatic
    cj5fanatic [OP] New Member
    Dale
    Lynnwood, WA
    67 CJ5
    77-1/2 231 odd-fire V6 w/Offenhauser intake & Holley 300 CFM, 64 Buick Special drivers side manifold, 225 V6 passenger side manifold, 3-row radiator w/electric fan, hydraulic clutch, Saginaw 2.5:1 4-speed using Advance Adapter to Spicer 18 w/Tera-low 3.1:1, OD, Koenig PTO, Ramsey PTO winch, 4.56 Diffs, Offset flanged Dana 44 rear w/Detroit Locker, disk brake Dana 30 front w/Detroit True-Trak, 73 tub, full cage, front & rear gas tanks, fiberglass tilt nose, 74 Cherokee tilt column and Saginaw power steering, Rancho Freedom Rider 2-1/2" lift, Rancho 9000 shocks, 11.50x32 BFG Mud Terrains, 15x8 black dish wheels
    Hello,
    I purchased my first Jeep, a 46 CJ2A while in high school in 1974. It had the flat-head 134 cu in 4 cyl w/6 V electrical system for 12 years. Then I installed a 225 V6 and converted to 12 V. I also installed Saginaw manual steering. The 2A body rusted out and I installed a 3A body.
    In 91 I sold it and started building my current Jeep:
    67 CJ5 frame w/reversed front shackles
    Buick 77-1/2 231 odd-fire V6
    Offenhauser 4 bbl intake manifold
    Holley 300 CFM carb
    Saginaw full syncro 4-speed w/2.5:1 first gear
    Advance Adapter transfercase adapter
    Spicer 18 transfercase w/Tera-low 3.1:1 low range
    Overdrive
    Koenig PTO
    Ramsey PTO winch
    4.56:1 Differentials
    Dana 44 Offset flanged rear axle w/Detroit Locker
    Dana 30 disk brake front axle w/Detroit True-Trak
    73 CJ5 body
    Front & rear gas tanks (24 gal total)
    Full fiberglass tilt nose
    Full cage
    74 Saginaw power steering
    One piece tie rod
    Ranch 9000 shocks
    I also own a 52 Jeep trailer.
    I have been in three different clubs in the Pacific NW 4WD Assoc. However, I am currently not a member. The 67 CJ5 has been to the Rubicon twice.
    Dale
  2. Jan 23, 2021 at 9:17 AM
    Welcome @cj5fganatic ...you have a very interesting jeep history
    LYFZGOOD likes this.
  3. Jan 23, 2021 at 10:09 AM
    Welcome from north central West Virginia :oldglory: we love pictures!!!
